When I print or copy the top 1 inch to 1.5 inches of the page is light and faded? Why
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Very slow PDF and large files printing
Change to print as an image.
Go to print then click on advance and select image.
SOURCE: the page is starts printing about 1 inch below the...
I am having the same problem too. the quality of the first page look crapy too.
this only happens to the first page i believe when the machine was out of power saving. if i print more then one file at the same time, only the first page of the first file was printed one inch below.
i suspect some cleaning might be needed. hope someone have a solution for this probelm. thanks,
SOURCE: I bought a used 2400W
First of all, here is the main ONLINE SUPPORT page for your model:
http://printer.konicaminolta.com/support/current_printers/mc2400w_sup.htm
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000066617.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Ensure you have the correct paper size selected in the PAPER TAB of your printer driver preferences options. See page 12 of the manual for details.
If you are not using the supplied driver for the printer, you can always download it at the main support page above.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
