SOURCE: xd picture card
You will need to do a firmware update to be able to use your new 'M' XD card. Also you will need a AC adapter to be able to use the update for your camera.
It is a Fuji site and it works.
Good luck.
http://www.fujifilm.ca/x3719.xml
SOURCE: Fuji Fine Pix F10 camera says ''card full'' when it is not.
If you plug your camera into your computer again and click Start > My Computer. Your camera should be listed under the devices there.
Double click to view what is inside your camera. You will have to browse to a folder in your camera with a name like DCIM (I can not be exact here since it can vary.)
Select and delete all the images you find on the device.
The problem here is that when you downloaded the photographs from the camera to the computer, you did not check the option to remove the downloaded photographs from the camera, freeing up the space for more new photographs.
SOURCE: display says card not initialized when a new xd
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/
you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
SOURCE: i accidently recorded several images on the
No you can't you will need to get the transfer cable for your camera. There are many places you can get them from on the internet. Here is an example:
http://www.amazon.com/dCables-Fuji-FinePix-F480-Cable/dp/B003HMTP4A
Thank you and good luck,
Lee
Testimonial: "thank you, you are right"
