When i switch on my tomtom one it starts up but the splash screen is out of sinc then just freezes tryed reset button for 30 secs turns off then does the same every time but freezes at a different point of the startup each time cannot turn off unit with button only by resetting it HELP ME PLEASE!!!!
Jump up and down on it about 27 times sorry 28 and see if that helps, it did me - i then went and bought a MAP
My philips dvd home theater system medel hts6510/12 is frezen when I turn it on the DISC and surround light will come if I press source bottom it want not come and I can't turn it off until I remove plug from the socket please I need your help boss
I'm having the same darn problem - the TT One XL just up and quit - having never bothered with map updates or the like. This model has both internal and SD storage. Neither work any better. It's not software, it's firmware. No amount of reinstalling seems to help. It boots and then stops at a light blue screen with a darker blue banner at the bottom. No map, no power button function. Frozen. Yet, it works if you operate it from TomTom Home - map is good, good SAT reception, can even plan a trip. I'm wondering if the touch screen is damaged and keeping it from starting up properly.
At any rate, don't get excited over reinstalling anything. I'm getting around to trying oxpox's approach... except this belongs to my father-in-law. :)
Sounds like the OS is corrupt,
http://www.tomtom.com/support/support.php?ID=2
Unfortunatly it is most likely the data on your SD card has become corrupt or the CARD itself had become damaged / faulty. Hopefully you had previously backed up your SD card to your PC ? . if this is the case all you need do is reload your tomtom files from the PC and onto your card. Hope this helps.
I set up the unit when I first bought it about three weeks ago but when I tried to use it today it won't give me any screen when I touch the screen.
I power the gps on and the screen stays on the tomtom one screen.
I was using my Tomtom One XL and it rebooted and always get stucked on the splash screen.
I have to reset the tomtom every time i want to turn it on
I set up the unit when I first bought it about three weeks ago but when I tried to use it today it won't give me any screen when I touch the screen. It is like it is on sleep mode. HELP W have tried switcing it off but it will not even do that.
startup screen frozen
I was using mine for about 1 to 2 months, one day i took it into my house to connect it to the computer to do the updates, and then when i whent back to my truck to turn it on..it freezes on the splash screen now i cant get it to turn on... only when i plug it into my computer.
