Washer filled with water and started cycle. got stuck on spin cycle so i turned it off. Turned it back on, aggitator did not turn but machine made noise as if it were on. Turned it off again. Now ill not do anythin. No noise. Power connector is ok. Circuit breakers are ok. Any ideas? It's 2 years old.
SOURCE: Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
SOURCE: GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
SOURCE: Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
SOURCE: Maytag turns on but won't aggitate
ahh sounds like the maytag drain pump, it seizes up and over heats the motor. look for belt under unit, pump is front right or rear right. buy the pump asm. They sell a pump by itself but you want the assembly at the same price, its a newer design
SOURCE: Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
