check the outlet first the check to make sure the power cord is pluggged in correctly there could be a problem with the on and off switch the motor could have gone out the power cord could be bad it would be a good idea to have the machine checked
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
If your washer doesn't seem to work at all, check these:
No power Lid switch No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
Hi check lid switch not working ,try insert in lid a roll of cartoon to the hole to struck switch, sometime the screw was rusted and falling down. the egagem of switch to lid was not hit so no movement of machine.
