Question about Toshiba Regza 37HL17 37 in. LCD TV
My Toshiba 37av502u goes back to initial setup screen to choose language. All color settings go back to factory settings (50%). Turner defaults to cable, but retains the channels.
5 Suggested Answers
Jason Morris
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 13, 2009
Anonymous
  • 556 Answers
SOURCE: Not all channels memorized during setup
YOU WILL HAVE TO PUT IT IN THE CABLE MODE BEFORE AUTOPROGRAMMING. IT IS IN THE MENU RIGHT BEFORE AUTO PROGRAM
Posted on Aug 18, 2009
as400jockey
AS400 Jockey
  • 3 Answers
SOURCE: White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Posted on Feb 06, 2010
Chi Chu
  • 8457 Answers
SOURCE: when I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
Posted on Mar 22, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Toshiba model 37AV502U TV
Keyboard issues and answers:
A problem that is more common than most people think is an issue with buttons on thecontrol keyboards of modern TV sets.
Recently for whatever reason I have seen more questions about this so I have composed this answer and solution for these kinds of problems.
It can be any button on the set-channel up/down or volume up down-you name it.
The symptoms are the same: channel will scan up or down andwill not stop-remote control has no effect on this---It can be channel, volume,or even input or menu if the set has those up front or on the side of the set.
All these push controls have something in common-beneatheach is a tiny momentary push switch-when pushed with the plastic button itperforms a specific task (vol up or down etc.).
What happens is the afflicted switch beneath the plasticbutton is bad-when released it is supposed to stop its function but does not.
Keyboard or button controlled features have PRIORITY over the remote control, hence the remote will not stop this fromhappening. Both the remote and thekeyboard go to the microprocessor in the set but keyboard is first in line.
How to resolve this issue?
Someone needs to get at the tiny pc board with the buttonsand locate the one associated with the issue (ie sound or channel etc) andunsolder that switch from the board-usually just two pins (may be more formounting only purposes) and then see if set does not have the issue with switchout of the circuit.
For the TECH minded with the board out test here theswitches with a ohm meter set to high resistance-any reading with button notpressed means a bad switch-seen ones that read 5,000 plus ohms-it may benecessary to unsolder more than one switch to locate the offender here butan open reading with switch not pressedis the rule.
I have taken the time to compose this answer as some do notunderstand what is happening in these types of situations---No magic wand orsmoke and mirrors here-have to disable the offending switch to know.
The beauty (in my view) of this kind of problem is if found, you really do not have to replace anypart-just operate the set with the remote with one button that no longerfunctions on the set itself-who could ask for more?
SD TECH
Posted on Jun 02, 2012
How can I change the language on the panasonic strada cn-dv255rd GPS from japanese to english?
suspect you may have acquired a Japanese (-and-Korean-and-perhaps-Chinese) -language-only model.
But in any case, language changing is usually the first screen on initial setup. If you get a screen of language with two buttons, on the lower left and on the lower right, you probably should select the left-hand button, then select one of (possibly three) languages. English being prodominant, the left-most button of three would be one to choose, if you have a model that can be set to English at all.
The initial setup screen with language choices, will probably be what you get once you reset the device to factory settings.
Aug 21, 2016 | Panasonic GPS
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
My Toshiba 37av502u loses it's settings
As goofy as this might seem, a large accumulation of dust inside the TV chassis could be the culprit. The dust becomes conductive and drains the charge from the capacitor that keeps the memory "alive" while the set is powered off. I'm a 40+ year veteran TV technician, but I've specialized almost exclusively in antique (1940's to 1970's) all vacuum tube sets for the past 15 years. I can get a dead 1946 RCA 630TS 10" B/W TV (worth about $2,500 as an antique) working again with about 10 hours of bench time. My new roommate, a lady I've known since we were kids, brought a Toshiba 37AV502U with the same "loses its memory" symptom when she started renting my spare bedroom recently. I opened it up looking for a bulging electrolytic capacitor or a dead RTC battery like some computer motherboards. I didn't find any suspicious capacitors and the only batteries this set uses are the AAA cells in the remote. What I did find was A LOT of dust inside the set. Cleaned the dust out, put it back together, and the set is holding its memory now when powered off. Obviously, the dust was creating a shunt path that was bleeding the charge away from the capacitor that stores charge for the memory.
Jan 30, 2014 | Toshiba 26AV500U 26 in. LCD HDTV
Eror code E000020-02a9
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Aug 02, 2013 | Office Equipment & Supplies
How do I change language settings on my Dell V313 printer
Printhead error
Apr 22, 2013 | Dell V313w AllInOne InkJet Printer
My toshiba satellite laptop lost power during. a restoration to factory default settings
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Apr 11, 2013 | Computers & Internet
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
The printer screen display is in chinese or other asian language therefore want to change it back to english How do i do that?
These are possible solutions. Try one of the following:
Change the language selection during initial setup
After you select a language, Language appears again on the display. To change the selection:
1 Press or repeatedly until the language you want appears on the display.
2 Press to save.
Select a different language after initial setup
1 From the control panel, press or repeatedly to choose Setup.
2 Press .
3 Press or repeatedly to choose Change Printer Default Settings.
4 Press .
5 Press or repeatedly to choose Language.
6 Press .
7 Press or repeatedly until the language you want appears on the display.
8 Press to save and exit.
Note: If you cannot understand the language on the display, see "Resetting the printer to factory default settings" on page 57.
Manual:
http://images.lexmark.com/publications/pdfs/2007/4800/v4924668_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2010 | Lexmark X4875 InkJet Printer
Reset
If you mean factory defaults, you do this through the BIOS setup.
During the initial boot, a message should flash on the screen telling you which F key to push to enter Setup.
This is, on most systems, F1 or F2.
The text menu normally shows a selection called Factory Defaults or Auto Setup or similar language.
Aug 19, 2008 | Averatec AV6130HS 20 Notebook
Focus
Use the Setup menu to select English or Spanish as
the language for the menus and on-screen displays.
Adjust Color Balance Automatically or manually
(PerfectColor TM) using six colors, Magenta, Red, Yellow,
Green, Cyan and Blue. Reset the Color Balance to the
factory default settings. Align the focus (convergence)
of the TV's projected light beams or reset the focus to
the factory default settings.
Jul 01, 2008 | Mitsubishi WS-65515 65" TV
Toshiba Regza 37HL17 37 in. LCD TV Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
