Sylvania Sytabex7-2 7" Tablet Express Plus Powered By Android 2.2 Logo
Frozen on infotmic screen - Sylvania Sytabex7-2 7" Tablet Express Plus Powered By Android 2.2
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
I have infotmic tab but im unable to download any apps or any thing how do i do this things please help.
Dear Eram,
To download apps for an Android device, you need to have (or create) a Google account - if you have a Gmail account, it is this same account.
Then, you have to search in your tablet apps for the Google Play app and touch on it. Entering Google Play, sign in using your account and you will be ready to download your apps.
NOTE: to enter your Google Play, you will need to have the Internet connection active and correctly set up in your device.
Hope you may find this helpful!
Best regards,
Miguel Luiz Martins
Kindle 4 frozen
screen frozen tried everything no luck
My infotmic android 2.3 tablet is not turning on
My infotmic android tablet is not acept to touch scream
Button stuck on tablet
Dear Michael,
If you have available at your home, try spraying just a little bit of WB40 in the button and try to move it back to its place depressing it and dragging it back with two matches or two toothpicks.
Hope you may find this info helpful!
Best regards,
Miguel Luiz Martins
Top Sylvania Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
CONSTANT AKPAH
CONSTANT AKPAH
Level 1 Expert
 Mikey
Mikey
Are you a Sylvania Tablet and eReader Expert? Answer questions, earn points and help others
