It seems that the camera when set to manual mode, which is mostly how I photograph, cannot "find" the objects or scene in front of the lens. It is not detecting the light level correctly whether that light is good daylight or is a low light situation. Again, in iA mode and some of the other automatic settings, the camera does not set the exposure correctly (badly underexposes) for the given amount of light. This has all happened suddenly since a few days ago I took some perfectly fine daylight and dusk low light pictures.
SOURCE: Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
SOURCE: Underexposed image on Auto mode
You can change the ISO setting also to Auto. If you have the advanced guide (see pp 80, 107).
Press the ISO button it will switch from various ISO setting to AUTO.
Do remember in Bright light , a lower ISO number like 80 will give you very fine images, while as the light level goes down, the ISO number will change to a higher number and the image will become more grainer.
I hope I could answer to your query.
Please do rate. Thanks
