Question about Ricoh Aficio Office Equipment & Supplies
When printing with a ricoh aficio c2800 on both sides the offset of each side is different
The printer offers double sided printing. But apart from the paper jams caused probably because the sheet is covered 100% with color, the printed results vary hugely in positioning on the actual paper. No matter offset settings from Indesign and Acrobat the Printed Sides can't be repositioned to mach because each printing job slightly varies in positioning up to 5mm! Problem of paper jams is solved by letting the sheets cool down and printing the sides separately. But the positioning isn't accurate enough to be of use.
Anonymous
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Canon imageClass MF6530
This is a "monochome printer" ie B/W, double sided is called duplex select this option on printer driver on pc
Posted on Dec 01, 2007
Anonymous
  • 1847 Answers
SOURCE: Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Posted on Sep 09, 2008
inkypete
  • 214 Answers
SOURCE: panasonic workio dp-1820, double sided printing take off
Look for a setting in the print dialogue box, about 2 sided or duplex printing
Posted on Apr 25, 2009
Anonymous
  • 15 Answers
SOURCE: Heavy static charge left on paper
On paper exit, is one grounded metal brush. Look if there is problem with it, is still there, and it shoud touch the paper.
Posted on Apr 28, 2009
Anonymous
  • 5 Answers
SOURCE: When printing a large document - about 200 pages-
Two options 1. print one page at at time, ie one sid the the other or 2. print odd pages then turn over and print even pages. it is a little tricky but can be done. on print options select which pages to print separated by commas
Posted on May 08, 2009
We have a Ricoh SP C250SF all in one printer in our office and we cannot get it off a default setting for double sided printing. Please help us
Morning!
When you go to your devices and printers , right click on the ricoh printer and click on printer properties , the go to the advanced tab on top and click on it , then bottom left there should be a option for printing defaults , click on it and select the double sided option there !
Nov 30, 2016 | Ricoh Aficio Office Equipment & Supplies
Error sc995-01 on ricoh mp c2800
spmode
5801 #
execute
then turn the machine off and on
sp mode
2111-3 # execute
2111-2# execute
2111-1#execute
3013#execute
watch video to fixing
https://youtu.be/-DGnULMHtD4
Nov 11, 2016 | Ricoh Aficio MP C2800 Copier
How to override login on Ricoh C2800
default username is "admin" default password is blank
Sorry if you were already using that.
May 16, 2014 | Ricoh Aficio MP C2800 Copier
Print clear film
Are you need a special film from copier machine,a fusing unit hot roller temperature is 195 C.
Dec 16, 2013 | Ricoh Aficio MP C2800 Copier
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
Do i need any driver if i connect Aficio 1035 to my pc. n wat do i need for it to be connected to my pc. tq
Does your machine have the Printer Option installed? Or the Print / Scan Option installed? If so, there would be a NIC input on the left hand side of machine towards the back....and print and scan buttons on the left side on your control panel. Type 1045 Printer option is what needs to be installed for the machine to be able to print. Drivers can be downloaded from this link to Ricoh.
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1035_45/x1035_45en.htm
Just choose your operating system.
Oct 22, 2009 | Ricoh Aficio 1035 Copier
Need to Double Side
press the "duplex" button on the operation panel
Jul 23, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Double sided is no longer an option with mac os 10.5.4
Go into the advanced settings of the driver and look for the settings that tell the copier what features you have. Make sure the duplex is turned on. Normally I set these up for Windows use and I have one client who uses a Mac and he did show me that the features do exist for the print driver.
Once it is enabled the double sided printer feature should work.
Dec 29, 2008 | Ricoh Aficio 1515 Black and White Copier
75 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
