Yamaha P95 Digital Piano Logo
A
Anonymous Posted on Jan 30, 2014
How do I transpose on the yamaha p 105 - Yamaha P95 Digital Piano
Jonathan Brown
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 27, 2015
Jonathan Brown
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2363
Points
5
You are probably trying to set the new pitch on the wrong octave. Try using the C above middle C as the center point.
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
1helpful
2answers
I have a Yamaha P-105. It is just over a year old and we have never attempted to transpose anything. Tonight I tried and it won't work. I hold down the DEMO/SONG and METRONOME/RHYTHM button
i would discuss it with the dealer you bought it from. He'll have you go though the commands again just to be sure. At that point he'll ask that it be brrought in for service or will refer you to a service center. If it is over a year old it will be out of warranty, but if you approch him polietly he may try to bend the time period for you.
Yamaha mm6 transposing by itself
Probably the transpose button on your keyboard has become short. You need to clean the contact by a cleaning agent such as WT-40 or similar one. If not, you need to change the button.
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Software problem, my keyboard prs s500 have lost it key arrangement order ,where by now key f is found in key g, .please help me how to restore its arrangement
Look in your manual under "transpose". The transpose feature shifts the keys up or down often up to a full octave. This allows you to play in ANY music "key" you know and generate sound in a different one for say a vocalist who only sings in another...
The Yamaha P95 is have a semitone out. Using the transposing function moves it up or down a semitone, however it's still out from concert pitch where it should be?
how come mine is ok, maybe it's depends on where you bought it.
<a href="http://bestdigitalpianoreview.com/yamaha-p-85-review">Yamaha P85 Review</a>
Keyboard seems to be stuck in key of D How do I get it back to C ?
On page 105 of your X5D manual, read up about "transpose". Setting the transpose shifts the notes plus or minus from the normal.
If you don't have a manual, you can download one for free.
Nov 13, 2010 • Korg X5d
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
