Just bought IBM thinkpad 380z laptop for $30 they said that they lost the password for it. When I turn the computer on the screen goes black and then you have a lock symbol that appears. Anyway of...
Battery fully charged, battery installed in the IBM Thinkpad 380Z.
Laptop off.
Turn the laptop over on it's top cover. Remove the Memory Compartment Cover. (Front of laptop facing you. Cover to the front right. Remove one screw)
On the laptop body, you will see the hole, for where the Memory Compartment Cover screw came out of.
Right below the hole you will see two metal pads. Copper or Brass. These two little pads are pretty close to each other.
Take a flat tip screwdriver,and touch the tip to both of them at the Same Time. The tip of the flat tip screwdriver, must be wide enough to touch both of those pads. Hold it there for Two seconds.
You are shorting the Power-On Password jumper pads.
Put the Memory Compartment Cover back on. Turn the laptop over. Press the Power On button, and hold it down until the laptop powers up.
If a Supervisor Password has bent set, as well as a Power-On password has been set, this will not work.
If so, past this point I suggest it will have to be taken to a tech, who will contact Lenova, (IBM now), and verify that you have purchased this laptop. Not stolen it. Then Lenova will give a password to the tech, who will enter it, and enable you to use it. You'll probably be prompted by the tech, to enter your own password at this point.
