Question about Ricoh Aficio Office Equipment & Supplies
May photocopy ricoh mpc 6000 ad toner error - Aficio Ricoh Office Equipment & Supplies
Anonymous
SOURCE:
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
Anonymous
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
Anonymous
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
Anonymous
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
Rick
  • 46 Answers
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Posted on Aug 28, 2009
Copier ricoh mpc 4500 add black toner
if you replace toner and still saying added toner then black pump is bad replace
Mar 06, 2017 | Ricoh Office Equipment & Supplies
Where are the ID/SENSORS in my photocopier ricoh aficio mp 6000
my dear you clean drum unit your trouble codes clear
Jul 16, 2015 | Ricoh Aficio MP 6000
HOW DO I RESET WHEN adding a new toner cartridge
There is nothing to reset the toner will load itself unless there is another problem. Make sure the insert plug from the old bottle came out before you placed the new bottle in.
Jun 11, 2015 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Ricoh mpc 6000 sc540 error code
my reecho mpc6000 calur macing problem yellow toner add , pl help
Jan 31, 2013 | Ricoh Aficio Office Equipment & Supplies
Firmware ricoh mp 4000
i can firmware ricoh mpc 6000, please sent to me phamgia6688@gmail.com.
thanks!
Aug 17, 2012 | Ricoh Aficio Mp 4000...
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
43 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
