How do I transfer photos from internal memory to laptop
You've got two possibilities.
Remove the memory card before connecting your camera to your computer.
Use the "Copy" command in the Playback menu to copy photos from the internal memory to the memory card, then transfer them fro the memory card as usual.
The "Copy" command is on page 108 of the manual: http://www.fixya.com/support/p509855-panasonic_lumix_dmc_fz8_digital_camera/manual-30307
SOURCE: on screen it says memory card error please check
Make sure the cards are 2GB or less, 2GB is the largest the camera can support. If they are, you may need to format the cards to use with the camera. Press Menu/Set to display the PLAY mode menu and select the item to set. Select Format and confirm by select Yes. The owner's manual says to perform this procedure when you get MEMORY CARD ERROR.
SOURCE: Photos stuck on integral memory?
When viewing pictures, select the 'Menu' option. Scroll down and on the second page there's a 'copy' function that can either transfer photos from internal memory to a memory card or vice versa.
I didn't know this was possible until today, either. Handy!
SOURCE: Can't download/upload photos from camera's memory; how can I transfer to memory card?
pg 16 of your owners manual:
• Picture data recorded on the built-in
memory or a card can be copied from
the built-in memory to the card or vice
versa. (P90)
See page 90
heres a link to your om if you dont have it
http://service.us.panasonic.com/OPERMANPDF/DMCTZ1-MULTI.PDF
SOURCE: Can I transfer internal memory photos on to the
Go into the menu and find "copy". You will have the option to copy the internal memory to the memory card.
SOURCE: How can I transfer photos from internal memory to
should have option for that in the menu,,,
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
