You can order from your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
RRP for Quinny Speedi front wheel unit is 27GBP RRP for Quinny Speedi rear wheel (each) is 37GBP
There would be a p+p charge of 3.99GBP or 8GBP on an order placed direct depending on the weight of the final order.
The clips on the standard Zapp fabric for it to be inserted into the chassis and attached correctly are not available as separate spare part items. It would be a case of replacing the seat fabric.
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
The quinny speedi should come with the adaptors to fit the bassinet (the quinny dreami) Once you remove the pushchair seat unit by undoing the clips and undoing the velcro the fastenings you then need to remove the 2covers or bumper bar(depends on model) above the quinny logo on the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. The carrycot is then place onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood.
HTH
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know.HTH
try contacting Dorel - the parent company for Quinny at www.dorel.co.uk You will find phone numbers for customer services and they can send you what you need.
