Hi, Make sure you have 240V to the dryer. Remove the lower half on the front panel and you will find the heat element under the drum right side.
Start the dryer and test the element to see if there is 240V to it. If there is voltage, change the element.
If there is no voltage, UNPLUG the dryer and test the thermostats and the fuse for continuity. If any of these do not have continuity, change it.
I hope this help you. Please let me know if I can assist you further.
Vic
SOURCE: Whirlpool Duet Dryer ( gew9200lw1): no heat
If your dryer runs, but does NOT heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
SOURCE: Whirlpool Duet Dryer not heating
FIRST YOU SHOULD CHECK YOUR BREAKERS MAKE SURE BOTH ARE ON. YOU NEED 110V TO RUN THE MOTOR BUT 220V TO HEAT.IF THAT IS FINE IT MAY BE A SENSOR OR A ELEMENT.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: My whirlpool dryer (Duet) will not heat. What
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If you need further assistance, please post back and let me know. I hope you find this information helpful.
SOURCE: replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
