Computers & Internet Logo
A
Anonymous Posted on Jan 31, 2014
Configuration IP problem configuration symbol 6048
5 Related Answers
Anonymous
  • 82 Answers
  • Posted on Oct 09, 2007
SOURCE: AT-8000S series
pls regonfigure all setup and configure one by one
Anonymous
  • 46 Answers
  • Posted on Aug 10, 2008
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
A
Anonymous
  • Posted on Sep 07, 2008
SOURCE: C3200 Network Configuration
I found the software on the website.
Anonymous
  • Posted on Apr 23, 2009
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Anonymous
  • 58 Answers
  • Posted on Nov 04, 2011
SOURCE: Symbol MC9090
this is because you are cold booting the unit. Everytime you cold boot a 9090 it re-sets all saved settings. You need to warm boot only unless you want the unit reset to default. any problems please mail [email protected] for support - we supply MC9090's in refurbished condition complerte with like new warranty incase you need any
How to fix "wi fi doesn't have a valid IP configuration
The issue could be caused if there is a miss match in the IP address configuration.
  1. Method 1:
  2. a. Press Windows key + X and select "command prompt (admin)". b. Type ipconfig /release and hit Enter. c. Then type ipconfig /renew and hit Enter. d. Type Exit and hit Enter.
  3. Method 2:
Wifi doesn't have a valid IP configuration - Microsoft Community
answers.microsoft.com/.../wifi-doesnt-have-a-valid-ip-configuration/4f2c1aca-afd1-49ee....just found this not sure if it will help you out.
How to change my router's MAC address Netopia 3397G
Using a router is a great way to create a home or office network without having to spend a lot of money.
As long as you have a broadband Internet connection through an Internet service provider, you can use a router to get all of the computers in your home or office connected.
If you have chosen Netopia as your router brand of choice, you will have to configure it to make your network operable.
Power on your Netopia router, broadband modem and computer.
Open your Internet browser.
Type the router IP address, 192.168.1.254, into the address bar. Hit "Enter" on your keyboard. Log into your Netopia router with the username and password assigned to you by your Internet service provider.
Select "Expert Mode."
After entering expert mode, you will see a menu bar at the top of the configuration window.
Click on the "Home" tab. Many Internet service providers will ship your Netopia router to you preconfigured.
If it is preconfigured all of the fields, such as IP address, subnet mask and default gateway will already be populated. If the fields are not populated, proceed to the next step.
Click on the "Configure" tab. Select "WAN." Select "ATM." Enter the "VPI" and "VCI" numbers provided by your Internet service provider.
Choose your encapsulation option.
For example, "Routed IP," "PPPOE," etc... Click "Submit."
Select "WAN" on the left side of your configuration window.
Choose the "VCC1" option. Select the option to "Enable Interface."
If you do not have your own IP address, choose the option to "Obtain an IP Address Automatically."
If you do have your own IP address, uncheck the automatic IP address box.
Type in your IP address if you have your own.
Enter your subnet mask.
This information can be obtained from your Internet service provider.
Select the "NAT" option if you are using your own private IP address for your network connection. Click on "Submit."
Ensure that there is a check in the "Gateway Option" box and "IP Address" is selected as the "Interface Type."
Type in your "Default Gateway" address.
This can be obtained from your Internet service provider.
Click "Submit."
Select the "Configure" tab at the top of your window. Select "LAN."
Select "Enable Interface."
Type in the IP address for your router and subnet mask. Click "Submit."
Click on the yellow caution symbol on the top right hand side of your window to save all configuration changes.
Click on "Save."
Restart your computer for the changes to become effective.
http://www.netopia.com/support/hardware/technotes/CQG_121.html
2helpful
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
1helpful
How to unlock cisco ip phone 7910
  1. Press **# in order to unlock Network Configuration on the phone.
  2. Press Settings.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) for Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Hp leserjet 4250n network ip change solushion
Print out the current configuration of the printer, Press the Tick button, navigate to Information, press the tick button, navigate to Print Configuration, press tick button.
On the printout find the current IP address. Open a web browser and type the IP address into the address bar, press enter.
The printer setup will be loaded into the web brower. Navigate to the network configuration so you can see the IP, gateway and subnet IP addresses.
You can now change these but once you have your browser dispay of the printer will disappear.
Type the new IP address into the web browsers address bar and you should get the new configuration displayed.
1helpful
2answers
How do i set ip address for new jet direct card on hp 4600 dn
Go here for the manual cause it's a bit hard to walkthrough. When the printer is on and ready, you want to click the menu button and scroll though to the configuration menu -> i/o menu. You can print a configuration age to see what the current address of the jetdirect card is. If you're comfortable with command line, you cna use telnet to connect to the jetdirect card and configure it that way.
1helpful
Wireless configuration problem. It lost parameters I had imposted.
If you are using a MC909X, after entering the static IP address and WEP key etc. via the Wireless Configuration Editor, you can export the profile you created by going to the Manage Profiles area, tapping and holding the profile name until the menu appears, then select export, it will create a registry file in the Application folder of the device that will persist after a cold boot, and the settings will will not be lost.
2helpful
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
