I have a scorche antenna from walmart with a longer antenna part I also have it in a pt cruiser and ran to my battery direct with 16 guage wiring two in line fuses and the mic that goes with it from factory
SOURCE: I have a Cobra 29 LTD with Bluetooth. I have no
if the antenna warning indicator is lighting during transmission then the antenna is either located and.or installed improperly or a defect exists in the antenna mount or the feedline itself, including connectors.
SOURCE: Cobra 29 ltd Classic no
Check speaker and plug external one in if you have it.
swap mic could be a broke wire or bad switch in handset.
check antenna and coax connections.
i know checks sound basic but they could save you a lot of headaches later
