well, its not the "circut breaker" aka the fusebox, so there has to be a problem with the regulator. when you say headlight "blows" do you mean the actual bulb burns out, the fuse burns out, or the light just turns off? it matters. on a side note, if your headlight stops working, its normal for all the other lights to get a little brighter due to the extra power for the headlight going to the others.
Sounds like you are not getting a charge from the alternator. You need to check battery voltage with a meter with the engine off, key off. Then again with it running, and the voltage should increase. If not, it's not charging.
keep the mobile phone ibelowa a lamp for one night after cleaning the water out with a ear bud or something
if this does not make it come on then there might be some physical damage and you might have to go to the service station again i think so
Render then BURN AVI Save to the computer. View the file. If AVI is clean burn DVD if not
Redo. Add more RAM in your computer & Apply Higher Video Cards
