Printer stops printing in middle of print jog. Says "error printing on HP Office Jet G85" and "the printer couldn't print intuit"
According to Intuit it may due to inappropriate printer driver settings, for resolve this issue follow these tutorial steps Problem Printing Transactions to HP Printer and if not have enough technical knowledge or need any guidance during this process follow Intuit Support Number .
SOURCE: Printer not compatible to quickbook forms
I brought up the HP printer solution chat line and was assisted by a very capable person who assisted me locating the problem.
Thank you for your response.
SOURCE: tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
