The lower keys starting at the low G, 17 white keys from the left, stopped working unless I play 3 or more at a time. it also sounds different when I do this. Neither the black nor the white keys will work on this half of the board, everything else is working fine.
SOURCE: keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
It is a WK-1630 model
