Question about Belkin Easy Transfer Cable for Windows 8
I want to transfer files from a Windows XP Laptop to a Windows Vista PC. Can I use the Belkin (MicraDigital) Easy Transfer Cable for Windows 8 to do this?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 32 Answers
You can go ahead and try this, but I think it would easier to send yourself emails of the files, or use an online cloud storage to transfer the files. Try Google Drive, or OneDrive.
http://www.drive.google.com/
Microsoft OneDrive
Posted on Jan 25, 2015
6ya staff
SOURCE:
Help for easy transfer cable
If both computers are connected to your network, you can easily enable sharing of the drive(s) on your XP computer, then connect to it from the Windows 8 computer and transfer the files over the network.
Aug 06, 2014 | Belkin Easy-Transfer Cable for Windows XP...
Ten simple sentences
What exactrly do you mean? Is this a problem pertaining to the Belkin Easy-Transfer Cable for Windows XP and Windows Vista?
Feb 16, 2011 | Belkin Easy-Transfer Cable for Windows XP...
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Old pc w/disk drive laptop no disk drive.
If both Pc's support the cable and software The cable which I recall was a null modem cable, then yes if your laptop has a serial interface.
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Belkin Easy Transfer Cable for Windows 8 Logo
717 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
