Magenta not printing, just giving a faded-yellowish colour insted
Called HP service today as I had a similar problem......and I was out of warranty....but they said this happens at times if dust get into the top of the printer and they have a recall on them because of that.....they are shipping me a repolacement....FREE of charge.
Have u used this printer quite a bit....? if so the following may be
the problem and I just did run across this recently in a printer we had
in the shop....I recently read in one of my technical magazines that
there may be a design flaw in the placement of the laser scanners and
the openings that protect them....it seems that excess toner dust can
readily get in to scanner area and specifically inside the scanner
assembly and accumalate on the scanner glass and lens. Just cleaning
through the opening in the back of the printer will not eliminate the
issue. Machine will have to be disassembled, scanner removed and opened
and the glass/lens cleaned with a q-tip....the placement of the fan
(behind cartridges, lower right) seems to speed this process up and it
usually becomes first notable with the magenta cartridge, seeing as it
is at the bottom of the printer closest to the fan. Hope this helps..
Inkworks
I am get the same problem. Replace it with brand new magenta. The demo prints out the colors but printing a page from the computer the i still get the same problem.
Dodgy refill? or gen hp carts?
When running color supply page it says there is lot of color for maganta but color comes out very light, almost light pink or worse, replaced cartilage but same problem perisists
My printer HP Color LaserJet 2600n do not print the exact color on the artwork. It seems that balck color is not working since, the black color test was printed in pink color.
I will appreciate any help in advance..
thnx..
Bojox
Magenta is a dull yellowish color, replaced with a new cartridge and the same thing happened. What should I do next?
in prints magenta colour comes dull
When I print from my HP Colour Laserjet 2600n the left side of the page is faded and the rest is normal. Yellow/orange etc is exceptionally dull.
What can you recommend?
Thanks
MAgenta cartrige replaced but it still doesn't print anythig "RED"
magenta cartridge not dark enough
grinding noise when printing and bad color
Remove covers
