The onscreen keyboard comes on even though i have a magnetic keyboard attached!
When I select a type box on screen the screen keyboard comes on every time, even thoghe I have a magnetic keyboard attached to my Surface Pro. Once I touch the on screen button to remove the on screen keyboard it goes down, but removes half the screen I'm working on. Then as soon as I click another text box the on screen keyboard returns and covers what I am looking at. This is driving me crazy! Any help please?
To type the "and" symbol "&" on your HKC notepad, you can try pressing the "Shift" key and the number "7" key simultaneously.
If this doesn't work, you can try using the on-screen keyboard. To access the on-screen keyboard in Windows 10, click on the Windows icon in the bottom left corner of the screen, then select "Settings" > "Ease of Access" > "Keyboard" and turn on the toggle for "On-Screen Keyboard". Once the on-screen keyboard appears, you can use your mouse or touchpad to click on the "&" symbol.
If you're still having trouble, you can try changing the language and keyboard settings on your device. To do this, go to "Settings" > "Time & Language" > "Language" and choose the language you want to use. Then go to "Region & language" and select the appropriate keyboard layout for that language. Once you have made these changes, try typing the "&" symbol again using the methods mentioned above.
When the keyboard is up, look in its lower right corner.
Do you see a key with the icon of a keyboard on it ?
If so, tap the key. The keyboard should go into hiding.
To open it, start an app that requires typing, like email.
Tap in the an area for a message, where you would type.
The keyboard should appear.
Hello Friends...
If you can't remember the passcode for your Kindle, you'll need to reset your device. Press the Keyboard key to bring up the onscreen keyboard. Type reset my kindle into the passcode field, and then use the 5-way controller to select Done.
The button next to the .?123 in the right corner (see image attached) that looks like an icon of the keyboard itself is actually exactly for this issue. Press and hold this button and two options appear- undock and split. Undock will pull the keyboard halfway up the screen for this exact purpose, split will cut the keyboard in half like an ergonomic keyboard. For people who text frequently and find themselves typing with their ipad in their hands; this is a friendly option! Naturally thumb texters have split the qwerty keyboard mentally and will find this a very convenient option when needing to type with only their thumbs. Your ipad holds many tricks and bad a** features you may not realize even after years of ownership. I highly recommend "tips and tricks" guides in the App Store to find all the fun included features!!!
Ensure that Wi-Fi is on. When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
Choose a wireless network from the list. Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location. Optionally, type the network password. Touch the Password text box to see the onscreen keyboard. Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long. Touch the Connect button. You should be immediately connected to the network. If not, try the password again.
Here is the URL with a possible solution to disable the onscreen keyboard on a tablet PC: http://www.tech-recipes.com/rx/1941/tablet_pc_how_to_remove_on_screen_keyboard/. Here are the steps from the site, just in case the URL dosent work:
TO DISABLE ON SCREEN KEYBOARD 1. Click the Start button.
2. Select Run.
3. Type in: regsvr32 /u "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
4. Click the OK button.
To restore the On-screen Keyboard:
2. Select Run.
3. Type in: regsvr32 "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
