The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
SOURCE: Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. [email protected] if anyone can help.
SOURCE: DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
SOURCE: Disc won't eject, stays in "RECOVER" mode
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
Just next to the eject button on the actual recorder there should be a tiny pinhole. If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD. Hope this helps!
