Nintendo DSi White Console Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nintendo dsi, music in AAC file format
On nintendo dsi, it requires the format for downloaded music to be in AAC file format which is not an option. is there a workaround on this?
Anonymous
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Jun 05, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
108393
Points
878
Jalal Sordo
Level 3:
  • Master 1,800 Answers
Jalal Sordo
Master
Level 3:
Answers
1800
Questions
Helped
590078
Points
5194
Yea download music on MP3 format and use any music format convereter in the web and enjoy music in ur ds
try Switch MP3 convereter
1helpful
I loaded songs to an sd cad - my computer will play them from the sd card - but when i put the sd card into my nintendo dsi xl,press the sd icon on ds - the screen says "cannot find any music...
hello, Computers can play any audio formats (ex:- MP3) if you have right codecs installed, but the Nintendo is made to play music in AAC audio format only.
so you need find a program to convert your music.for example the music files are in MP3 format you will need to find a program that converts MP3 to AAC format.
Why cant i download music?
hi there,
unfortunately you cannot download music directly onto the dsi from a webpage as the opera browser does not allow it or does'nt support it if you prefer. You can however put music on an SD card and listen to music that way. The music tracks need to be AAC format and the easiest way to get this format is through itunes or else if you have music in mp3 formay you will need to get an audio converter software to convert them to AAC. Hope this helps
Hello and good day, I just bought a Nextech SD card for my son's DSI. when we inserted it and tried to open the music files through it. there a message of " Cannot find any music (compatible AAC files on...
As the warning said the music files aren't in the correct format, the only one supported by your device - aac. Most likely the files are in mp3 format.
If you want to use them on this device you must convert them. Use this program for that:
http://www.softpedia.com/get/Multimedia/Audio/Audio-Convertors/AAC-to-MP3-Converter.shtml
How do you download music on a dsi
Hello sherribaxley
As far as I know, there is no direct way to download music onto your DSi. In order to listen to songs on your DSi, you will first need to copy the songs you want to listen to onto a compatible SD or SDHC card. Not all songs are compatible with the DSi. Some songs may be copy protected and will not work. The DSi is compatible with AAC audio files with a filename extension of .m4a, .mp4, or .3gp.
WHAT YOU'LL NEED
- A compatible SD or SDHC Card. The DSi is compatible with SD cards up to 2 GB and SDHC cards up to 32 GB.
- Compatible music files stored on a PC or MAC.
- An SD Card slot in the PC or MAC, or an external reader/writer
WHAT TO DO
1. Insert the card into the slot.
2. Open Windows Explorer (for PC) or Finder (for Mac) and select the drive being used by the card to open it.
3. Open another instance of Windows Explorer or Finder and navigate to where the music is stored.
4. Highlight the desired file(s) and/or folders, copy them, and then paste them into the first instance of Windows Explorer or Finder to create copies on the card.
If you need to convert the format of your music files, there are many freeware applications available to download on the web. I personally would suggest using iTunes, as it has a built in AAC converter.
Hope this helps. Please don't hesitate to contact me should you require any further assistance.
ajblaj
1helpful
How load music in the sd card to my nintendo dsi
If you want to play music on your dsi you have to convert it to aac files, most music is mp3 files but your dsi wont play mp3 files on your dsi unless to put them on your sd ames sd card, then if you put them in your system folder they open it they will play, but if you want to put them on a sd card they into the side sd slot you have to convert them, the way to do that is to download itunes, unless you allready have it, they play the track or tracks you want on itunes, stop the track and right click the track and click create aac version, wait for it to convert, you will hear a ring when it is done, then right click the converted file and click show in windows explorer, then put your sd card into your pc and drop and drag the songs you have in the windows file, you can put them in a music folder if you like, then when you have all the music you want on the card, put in into the side slot on your dsi then turn it on and open the sd card folder and you will see a music file, then open it a play your music, hope this helps you, cheers Roger M.
2answers
I downloaded music onto a sd card but the dsi will not read the music on the card
Your music has to be from i-tunes or it has to be AAC file. Good Luck :D
5helpful
2answers
I dont know how to put music in my r4i
Your friend is right in part, if you want to put music on your r4i you can, if you drop and drap the music you want onto your sdcard like you would games, you can keep them in mp3 form, i did this for my grandaughter, when i put them on the card i dropped them onto the moonshl folder, then when you turn the dsi on you go to the moonshl folder and you can find the music their and play it, when your friend said you have to convert to aac files thats if you put them on a sdcard on the side of the dsi insert them, if you do that you have to convert to aac, the dsi will not play mp3 files, but it will if you put them on the games card and drop them onto the moonshl folder, if you want to convert your files for the sdcard on the side of the dsi, what you have to do is download itunes if you have not allready, put the music you want to play on your nsi into a playlist on itunes, click on the song then click on where it says create aac version, then when you do that you will see itunes converting it, when you have done that with all the songs you want, right click on each track that itunes has converted and click on where it says show in windows explorer, then when you have all the songs in windows explorer folder drop and drag them all to your sdcard, then put the card into the side slot of your dsi, turn on your dsi, and find the sd menu and their you will find your music, hope this helps you.
2answers
How do you play music saved on an SD Card?
1) frm da music on iTunes, right-click,then click on CONVERT 2 aac.another track(identical) should come out.
2)after completing step 1, go 2 my computer nd open the SD card up,create new folder or use da one u used 4 ur other music.
3)after step 1&2 copy nd paste ur song(s) to the folder u had open.hope dis helped
P.S. make sure u converted ur songs 2 AAC(aac) or else it wont work.
3helpful
How to download songs from computer?
The new Nintendo DSi console can now play music, however it can only play AAC file type music, so if you have MP3 type, converting it is as easy as pie in iTunes. Also, once you have converted the songs, you need an SD card to store the songs in, and once done, you can put it in the DSi SD card slot and then play your music.
Hope this helps.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
