If it's a newer tablet it should be rechargeable. And a red battery light indicates the need for it to be charged. On one of the side edges of the tablet there should be a micro USB or other port for a charging chord to plug into.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
You have a contact issue with your battery. ..even plugging it in you must have a good connection with the battery. I would try this take a piece of cardboard or paper and fold and wedge it in between the battery and the outer edge of the battery recess not where the gold colored terminals are located. Sometimes the battery don't make proper contact and this will ensure that it does. After doing this plug it in and let it charge for a while. When the icon for the charging battery gets to about the middle of the battery then hold down the on button until the icon disappears let go of the button and see if it works ok
Its sounds as if your battery has gone open circuit which means if is now dead and requires to be replaced. Dont continue trying to charge it as you may cause damage to your tablet or cause it to overheat and start a fire.
