Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps.
Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
