I got an F51 code on my Maytag Bravos XL washing machine. I looked on the bottom and it appears grease has been thrown from the bottom of the machine. Could this be a bearing problem and if so can I get a bearing or is this an all in one unit with the tub?
SOURCE: F51 & SD Codes --
remove what piece 10 times? not clear on armature. is that the circuit board in the plastic piece, the holder containing the circuit board, or the piece that connects to the circuit board from harness?
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Well the failure is Motor RPS Failure. Depend how he consider the charge for parts+job.
I am sorry. Try to locate another tech service.
God bless you
Hi David R, I want to help you with your problem, but I need more information from you. Can you please add the model# in the comment box?
