Washer works fine, then gets to rinse cycle and water runs in but does not fill, just goes straight out the bottom.
Did this once before, turned off and started cycle over and it worked fine.
Now, however, no matter where i start it in the cycle the water comes in but the unit will not fill at all.
Any ideas what is wrong?
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
