I am recovering my daughters kurio 7s. I accidently erased all of the pre loaded aps. so I have down loaded the recovery file, but when I plug in the kurio 7s to my computer its not connected...... it charges while its plugged in but just will not connect to the computer? why is that?
SOURCE: kurio kids tablet won't start up
I fixed mine like this, unfortunately you will lose all your data on the system.
1) Whilst holding down the Power button, hold down the Volume+ button for about 10 seconds and let go.
The table should boot into a screen with an Android with a open chest and a danger sign on top.
2) Press the Volume+ button, and the recovery menu will appear.
3) Press the Volume- button, to move to "Wipe data/Factory Reset" and press the Power button to select that option.
4) Press the Volume- button to move to "yes" and press the Power button to accept.
Now the system will wipe the data and factory reset the tablet.
5) When it returns to the menu, make sure it is on "Reboot system now" and then press the Power button.
The tablet will now reboot and should load.
SOURCE: reset kurio 7 tablet to factory settings
press and hold VOL+ and Power button simultaneiously.
http://www.kurioworld.com/us/pdf/Kurio_Manual_US.pdf
SOURCE: why won't my kurio 7" tablet connect to wifi
I had this problem with my son's Kurio over Christmas and found that connecting to wireless in Kurio mode was impossible. If you go to the parental mode and click the switch to Android button there are settings for the wifi in the Android platform settings. You can set up there and then go back to the Kurio safe mode for the children to use. Hope this helps...
SOURCE: kurio LCD screen broken
can the kurio 7 screen be fixed if i have broken ( line down the middle of screen and not geting anything picture wise)
SOURCE: forgot password for kurio 7
power down. then press vol +/- homekey and last power button.
when kurio reboot let go home button and volume down, just hold vol+ and power that should get you in recovery mode, navigate with vol+ and - enter with power button.
factory reset enter.
erase cache enter
reboot device
thats it. i have spend weeks with kurio7 i have rooted it flash it,bricked it and more good luck
