eLocity A7-004 7-Inch Tablet Computer - Black Logo
A
Anonymous Posted on Feb 02, 2014
Elocity Tablet A7 will not allow me to wipe all data?
FORGOT PASSWORD AND DID A HARD REST. IT SAYS I WIPE/FACTORY REST CANT BE UNDONE
Forgot password how do i reset the nextbook
hard rest
hold down power button and the volume up button till the android man comes up with all the writing
then go down to wipe data by using volume down button
highlight the wipe data press power button to ok
then the wipe data finsh it will come up with writing again go down to reboot/restart highlight reboot and restart press power button ok it then your tablet will restart it
2answers
I cannot remember my password to get into my tablet
hi John.
i think you will have to do a hard reset to sort this out.
Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
More items...
What do I do if I forgot my password to unlock to my tablet? - Trio ...
https://support.triotablets.com/.../201746559-What-do-I-do-if-I-forgot-my-password-to-...
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
or before you do anything go to this link and have some more off a read up.
cannot remember my password to get into my tablet Google Search
I forgot my password for my nextbook tablet. serial no.yfg0414022138.How do I log into my tablet or reboot it to factory settings?
make sure you do this right or you could end up in more trouble.
if you are not sure what to do then dont do this..
Simple video on how to hard reset Nextbook Android Tablet. Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe data navigating with the volume buttons and then to wipe data.20 Aug 2013
Nextbook Android Tablet Hard Reset - YouTube
or read this before you do it..
How do you hard reset Nextbook device
I have a Galaxy Tab 2 10.1 and I wish to reset my password.
NOTE: You may have to wait 30 seconds-1 minute when performing each step.
If you don't want to lose DATA there may be a "Forgot password?" option in which case google will reset the password via your email. If this option is not there then follow these steps.
To perform factory/hard reset please follow those steps (you will lose everything):
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
  • Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
  • Allow several minutes for the reboot process to complete..
  • This is all i could find on the internet so not sure if its what you are looking for.
I forgot my pattern and now I can't get in. What do I do?
Then you must do a factory hard reset, this will reset the phone and wipe all data.
How do i unlock my VisualLand Tablet ? I forgot my password.
Steps to Hard reset the Tablet:-
Hold and Press Power and Volume up button
Recovery menu will appear
Select it and Choose Wipe Data
Select Yes- Delete all user data
Different Hard reset factory wipe methods for Android Tablet
Samsung forgot phone pattern
You can remove your lock by a hard reset. This procedure will erase your personal data like accounts, other passwords and etc.
- Switch off the tablet. (To force shut down, pres and hold the Power button more time).
- Press and hold the Power and the Volume Up keys.
- When you see the Samsung logo, release only the Power key.
- Use the Volume Up/Down keys for scrolling and the Power key for OK.
reboot system now.
This procedure is same for Galaxy Tab 2.
3helpful
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
* Allow several minutes for the factory data reset process to complete.
* Allow several minutes for the reboot process to complete.
Forgot my password on my ereader and it was new
You can perform a hard reset to completely wipe out the tablet this will also remove any passwords and configurations. Note: This will also delete all the data currently present. The process for a hard reset differers based on the make/model of the tablet.
The most common way to factory reset an android device is these method. 1. turn off your device 2. Press the your Volume up button and power button at the same time for a period of time 3. you will see the android image appear on the screen after that you will see some options 4. Choose the WIPE DATA/FACTORY RESET by moving your selection using the Volume buttons 5. Select it using the Power Button
5helpful
2answers
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Top eLocity Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an eLocity Tablet and eReader Expert? Answer questions, earn points and help others
