Home Security Logo
A
Anonymous Posted on Feb 02, 2014
Clear error code on ekb500
How do you clear an error code after the problem has been fixed everfocus ekb500 keyboard
I just purchased a everfocus ESK1000 doesn't seem to work with hikvision ip camera's any ideas?
sure lots of Ideas, this is camera sercurity system right and not really a computer at all. sure and posted to wrong forum sure.
the cure is one place only, here.
everfocus ESK1000
call them ask them for web cam support,
here they are only they set the rules for all possible cams used.
https://www.everfocus.com/support/tech-support/
note it ask for country first.
4answers
How to reset error code E000-0000 canon 2202
Something similar to this:
1. In standby mode,press the "Settings/Registration" key.
2. Press the"Reset" key.
3. Press the"Back" key.
4. Press the"Settings / Registration" key.
5. The service modescreen is displayed.
6. Scroll to Printerthen choose Clear
Use the"Back" key to exit Service Mode
Formatting disks for ecor4f
The only way to fix a disk failure is to replace the hard drive. Once hard drive is replaced, if the unit doesn't give an on screen display
stating 'new hard drive detected: format now?' go into the menu
, to the disk section, & select 'format'. Problem should be resolved.
Samuel Morris
Camtek Of NY Inc
I’m happy to help further over the phone at https://www.6ya.com/expert/samuel_de7f55954e381a6f
I want to find a good app to open copied video from everfocus home security cameras
You can use restore to take the computer back to a date that you know that it worked. You can use right click and open with to set the program, you can reinstall everfocus. You can manually set the file associations.
3helpful
2answers
Forgot login password
Default User and Password on Everfocus is usually
Admin
Admin
Nevertheless, you should contact your local distributor, and after providing the product serial number, they can generate a reset user and password, that shall be used only once, and then, you must enter a new user/password combo.
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
53helpful
6answers
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
2answers
What is a 301 Keyboard Error and how do I correct this problem.
The motherboard has device controllers that read id #'s of your hardware. When a device fails, a fail code is thrown out which is attached to the device id. Sometimes when en error has been cleared the code for that device may not. Try to boot the computer with the mouse removed & a different keyboard. Shut down & install the mouse & original keyboard. Let me know what happens
4helpful
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Top EverFocus Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an EverFocus Home Security Expert? Answer questions, earn points and help others
