If the
washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_topThe motor coupling is located between the drive motor and the transmission and takes the place of a drive
belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the
rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub
rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switchIf the switch requires replacement, a new one can be purchased on line at
searspartsdirect.com, pcappliancerepair.com,
repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so
shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
the model number is 2624622..the serial number is CR5260179 and the id # is was010201700528...if it is the timer where can I get one?
sorry my model number is WAS010201700528..i hope that helps..please help me! thanks :)
the model number for my kenmore washer is 2624622, its a top load washer...it will drain when i use the knob to advance it to the next cycle but it wont advance out of the cycle that its in it keeps spinning or agitating..i sorta smelled a burning scent but i'm not entirely for sure it is only there when you open the washer and not behind it...
the one who responded said:
Maytag317
Maytag317
Rank: Guru Kenmore ExpertKenmore Expert
Rating: 93%, 223 votes
Hi, It sounds like you timer has gone bad. Would need more of the model # ro be sure on what type timer you have.
Please let me know if I can assist you further.
Vic
I got my washer at rentway and that was the model number on the back..the one inside of the lid was lost the serial is cr5260179 and its a 70 series model the dryer i got w/ it is a 70 series....its a two speed washer with 3 cycle combinations...its a heavy duty...and there is a part number on the back that says 8526032
