During the wash cycles the pre wash hose pressurizes and pops off. Does that mean I need to replace the water inlet assembly?
SOURCE: Water Pressure Woes
There is a water level marked behind your machine; your outlet tube should not go below this level; the wall outlet drain should be high enough. Then your water will remain at the correct level in your machine. See that the valve in your wall to the inlet is completely open before you turn on the machine for your wash.
Your pump pumps waste water OVER the level marked on the rear of your machine. The water level marked is quite important for a successful wash.
SOURCE: water leak
You have to search carefully for screws that hold the top down.....suggestion.....
SOURCE: I found water under the washer. I took the top
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
SOURCE: Low water flow into washer. Rust-colored grit
Its normally held by two screws with a internay hose fitted to it should be quite simple o replace, make sure you fit inlet Filter too ,will stop dirt going into and damaging the valve in future, may be idea to get hot fill /feed tank cleaned....
SOURCE: Water filter at inlet hose on LG WM2016CW
Following a 1E error I found the gaskets in both supply hoses had perished and the debris had blocked the mesh inlet filters, causing the grinding noise that the pump makes when it can't get water. The original LG filters are indeed removable, in bits. Their little plastic tag for pulling them out snaps off so you end up digging the filter out, just be careful 'cos there's another mesh behind the filter on the hot and there's a rubber seal behind the cold one. Easiest thing is to forget replacing them with original parts and get the old fashioned kind from Lowes etc, $2 for a 3 pack, these fit into the end of the supply hose and are a rubber gasket with mesh in the middle so you won't even need to buy gaskets to replace the ones that fell apart.
Hi
You'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
