I understand that it means the thermostat is in recovery mode. I understand the fix is to remove the face plate and slide the switch to disable the feature. What I don't understand is what the feature is for and what might cause it to need to recover or what disabling this feature might do.
SOURCE: Hunter 44360 thermostat
The message means the tstat was in recovery mode, I would suggest just disabling this function to prevent it in the future. Remove the tstat from its base and look on the back there will be a recovery switch just slide it to the other setting to disable the feature
SOURCE: i need a new manual.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
SOURCE: hunter fan 44360 won't turn my furnace on
I am having the same issue the fan turns on when you turn it on but it is just a fan with room temperature blowing out.
SOURCE: hunter prog thermostat 44360 flashing
Just hold down the two buttons for 5 seconds and it will be reprogrammed.
Good luck.
