SOURCE: my whirlpool awm 5125 wont fill up at start of
if it has just been installed check that the water tap has been turned on and the hoses have not been bent or twisted if these are ok you may have to replace the solinde valve in you machine
SOURCE: i am trying to locate
the brushes are on the motor which is located at the rear of the machine sitting just under the wash unit.
You will need a 10mm spanner to remove the bolts holding the motor on. unclip the wiring to the motor and remove.
the carbon brushes are located on the rear of the motor - one on each side of the commutator,
you will need a philips screw driver to remove the brushes
SOURCE: whirlpoolwashing machine main bearing noisy can i
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
SOURCE: looking for operating manual for whirlpool 5125
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
