My 93 Escort goes to high rotations, all by hit self...
Hi, i've a 93 Escort, and my problem is that the car goes to high rotations, all by hit self. Other times, for exemple in a traffic jam , it seams that the motor is going to stop, and it let's me down when i have to acelerate... What should i do??
never mind "A"join the club there keep taking the pills
take a screw driver and short out the battery wire to the small terminal on the starter this should spin the starter over and the engine at the same time if nothing happens the solenoid cap on the starter is faulty, you should here it click in to spin the motor up
if it clicks but still no go then its the starter motor its self likley to be brushes
it sounds more like crank case is not venting properly. check your PVC and make sure your not cloged.,
Your engine needs air to be able to move around so it doesnt turn into a pump. if you get your PVC clogged oil can start either burning or leaking past rings or spitting out of your gaskets.
try that first,
otherwsie i would have to asume you have a tired engine.
If this is a manual transmission the clutch has burned out, it may need to be replaced, if you do not do your own mechanic work I would suggest that you take it to a good local repair shop and have them check it out. If this is an automatic I would still suggest the same, but the actual problem could be more complex. Hope this helps, let me know.
yes, it will hurt the engine. if the engine is running when the belt breaks, you can have the top of the pistons hit the intake and exhaust valves..... very bad. replace the belt before this happens
hi there there probley is no diffrence but make sure they dont rub or scrape if they do u can go lower profile tyres but it may also put you speed o out a lilltle bit
