My hp pl5060n 50 no in. plasma hdtv was no sound and no picture there is power when you turn it on but the screen was blingking black and gray .
SOURCE: 50 inch HP Plasma Gone Wild...
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
SOURCE: Black screen on HP PL4260N 42? Plasma HDTV
The problem is the "Y-SUS" board. It is inside the set on the left side with several aluminum heat sinks, under the left side brace bar. You can order this board from Union Electronics at www.ued.com .Search for part number: TNPA3243AB-PA
It lists for about 115$
SOURCE: I have a hp pl5060n 50
SORRY IT LOOKS TO ME UR SCREEN IS SON THE WAY OUT
CALL HP SERVICE CENTER AND TELL THEM UR PROBLEM
SOURCE: HP PL5060N 50 my plasma will not start, I have a
The "Clicking sound is what gives it away. It would seem that your unit has some sort of PSU
fault, or a problem that is shutting down the Power Supply Unit, PSU. This
happens so that no further damage, and possible fire will occur.
You need
to take the unit to a reputable service centre/man and ask for a firm
"Quote" for the work to be done.
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
