Question about Miele W310 Front Load Washer
Yellow light flushing at rings - Miele W310 Front Load Washer
My ps3 keeps swiching itself of power light turns yellow then flash red
Sucks. You have the yellow light of death. kinda like sonys version of the red ring of death.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
My PS3 will turn on for maybe two seconds then the green light flashes to yellow and then turns off. what is wrong with it?!!
i think thats the yellow light of death (ps3's red ring) http://answers.yahoo.com/question/index?qid=20080721011745AAsUsoC
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
I have a 1997 Kohler Command CH25S in my small crawler tractor. It has 229 hours on the engine and it uses almost 1 quart of oil per hour! I checked the spark plugs and one is badly oil fouled. The...
Even though the engine is 13 years old but has low hours it could just be that the rings are gummed up and sticking in the groves and not doing their job properly. Before you consider pulling the engine apart for a ring replacement and bore hone, you could try this procedure.
Remove spark plugs and pour some engine flushing product like Wynns or Nulon into each cylinder. Turn engine over by hand to distribute the flush around the pistons and allow to sit for a day or so turning the crank occasionally and adding small amounts as the flush drains past the rings. The flush should soften any build-up of gum around rings and the bore. Before replacing plugs use a torch to see that there is not excessive flush sitting on top of pistons. If so wind over with starter to blow out excess. Replace plugs and put any remaing flush in sump and then fast idle engine until hot and then drain and replace oil and filter (if one fitted).
However if rings are badly worn there may not be much improvement and it is possible the oil use will increase. The cylinder with the badly fouled plug may also have a broken ring/s. Oill changes should be done every year or after 50 hours running, whichever comes first.
Let me know how you get on by posting a comment. Myki R
Oct 19, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Playstation 3 (PS3) Console: When it turns on light goes green then yellow and ...
yellow ring of death. there is no repairing it. you have to get a new system.
May 07, 2010 | Sony Playstation 3 (PS3) Console
Flashing red light
yellow light of death, ring playstation
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
Yellow ring on screen of KDF-E50A10 Sony Wega
The optical engine has a build up of dust. This can cause yellow shapes and blotches to appear. It is no easy task on this model to dismantle and clean the engine.
Sep 28, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
3 red lights and yellow power supply light
at the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Aug 03, 2009 | Microsoft Xbox 360 Console
Yellow Light
You have what is called the "yellow Light of death". It is the ps3 version of the Xbox 360's Red Ring of Death. Use these videos
Jul 05, 2009 | TouchStone Turok
Miele W310 Front Load Washer Logo
29 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
