Question about Sony BRAVIA KDL-46W3000 Television
Slow moving (RIGHT SIDE) and dark panel (RIGHT SIDE-HALF TV PANEL)
  • theodgr
    theodgr Feb 03, 2014
    also many times the image lost , only sound , remote work ok, no blink errors
  • theodgr
    theodgr Feb 05, 2014
    after heating t-con dark panel become normal, but remaing the problem with slow moving (refresh to right up side of the screen)
Half the screen on a ln46a650a samsung led tv is very dark. Its better with a bright scene. Also the dark side the right side hase a small vertical band or box. The far right is also slow, ghosty...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 03, 2015 | Samsung Televison & Video
LN-T4971F dark on the right side of screen.
Hey Steve,
Sorry to be the bearer of bad news but you have a bad LCD panel tab. There are videos on youtube that show you how to repair this but they are temporary in nature.
Jun 28, 2013 | Samsung Televison & Video
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from www.tvrepairworld.com
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
The screen on my samsung ln46a550 lcd tv is dark on the right side when I first turn it on. After about 5 to 10 minutes the right half brightens up. I also have a 3
Bad news, the LCD panel in your tv is going bad, call Samsung and complain about the problem, it is a manufacturing defect. It would cost more than a new TV to replace the "panel" or LCD screen. Good luck.
Jul 24, 2011 | Samsung Televison & Video
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
Right side of screen becomes discolored and fuzzy after 15min
if its an lcd, it could be a bad lcd panel
does the menu or volume get distorted or dark too?
yes - likely lcd panel
no - video board (main board) problem
a technician would use a can of "freeze spray" to find the issue inside, by cooling down the parts until the problem goes away.. the part you froze to reverse the issue is the bad part.
Jun 06, 2010 | Televison & Video
Half of my lcd tv gets dark no picture
Find your warranty papers....may be a defective screen.
Apr 21, 2010 | Samsung LA46A550 46 in. HD-Ready LCD TV
42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like www.flattvparts.co.uk where you can search by TV model number.
Oct 27, 2008 | RCA L26WD26D 26 in. LCD TV
Sony BRAVIA KDL-46W3000 Television Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
