Have you done a channel scan? This can take a few minutes but it locates and lists all channels If you've not done this already, go into your menu, channels and be sure to enter the receiving input whether it's antenna,cable, or satellite, start your scan and see what channels you're receiving. I sure hope this helps and good luck
probably the camera is either analogue or video . How was it connected to the TV via the Aerial Cable or via an AV input
If the camera is Analogue it may be on a ATV channel. So you would need to switch the input Source on the remote for the tv and check the ATV channels. If it was on a AV then try checking the AV input sources.
The free view channels is probably DTV source . .
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Firmware corrupted. Re-install it with the latest one. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/
hello, i don't where you live but there are no analogue signals being broadcasted any more. if your in england you will need a freeview box, some tv will switch off if they are not receiving a signal regardsshaun
The problem has cleared itself a day later after being switched on/off a few times.I suspect the 'computer part' of the TV (channel processor, instruction decoder etc) received maybe a power glitch or an illegal infrared instruction (2 remotes used at once for example) and 'locked up' leaving just the analogue side operating. I was going to continue happily using it with just the analogue side slaved to my Hd recorder for digital signals but it seems to have got over whatever it was that upset it.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
