I need the codes for a one for all remote control in order to program LG plasma tv
0011 0025 0049 0050 0054 0055 0101 0107 0110 0119 0152
0165 0166 0168 0181 0182 0195 0235 0250 0303 0379 0380
0414 0421 0433 0460 0465 0611 0613 0658. These are the codes to try. If you wish to get more; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
SOURCE: have an urc-3220 remote control
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: I have a LG TV & need code for one for all remote URC3021B00
LG started out as Goldstar, merged with Lucky Corp., to become Lucky Goldstar, LG ;-)
Although your remote doesn't list any codes for LG, one of the Goldstar codes may work.
Try 0030, 0056, 0178.
If that doesn't work you may have to try the "Search for Code" feature by first turning your TV on, then follow these steps:
1.On the remote control, press TV once
2.Press and hold SET until the LED (red light) blinks twice,
then release SET.
3.Enter 9 - 9 - 1.The LED will blink twice.
4.Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5.To lock in the code, press and release SET.The LED will
blink twice.
The URC-3021 is a 2004 basic model without any learning capability, if you are unable to find a code, it may be time to buy a new remote.
There are newer, low cost universal remotes available at Walmart, Target, K-mart, and other retailers, that should have a more up-to-date code list.
Hope this helps, Greg
SOURCE: REMOTE CONTROL CODE FOR HAIER TV
We have a Haier TV model 3 HL32R2a, the cable remote no longer turns the set off or on or controls the volume. We can only do that with the tv remote. Tried putting in the universal code, and the Haier code and it didn't work. Please help.
SOURCE: I NEED CODES FOR TV DAYTEK AND HOW TO PROGRAM THIS
we have a 21" daytek hi def tv with no book or control. help?
