An area rug was washed. The rubber backing came loose and is clogging the water outlet. We cleaned the tub drained water from the small hose near the filter(it drained very slowly only when keeping the line clear by blowing into it) and emptied the filter. On the second try the water filled (and continued to fill halfway up the window until we shut water off) We ran the wash cycle for a short time and drained water from the drum over night. The filter had nothing in it but on close observation with a flashlight under the stainless drum there is about 1/2" to 1 "of residue under the drum. How can this be cleaned out. We also called for a certified service tech but were told it would take 2 weeks to get one out to us. Not a very good response considering we live in a major city.
¡æThe drain pump filter
• The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Yup, Same here.
The screen shows a backward 3 , and it won't drain.
wil wash water will not drain and will not activate spin rinse cycle.
