My printer wont print, it gives giving me an error message, saying "supply memory error". it does all other things like scan, and photocpy, but it just wont print documents sent to it
if you update drivers or used windows 8, HP make drivers check if cartridges are original, you have limit used of the printer, if you install original cartridges resolve you problem.
hi.
this is all i could find,go to this link and the bottom of the page if you need more help.
Microsoft has a printing troubleshooter that can help to identify problems. Click the Fix it button, download and run the program, then follow the steps in the wizard. You can also open the Control Panel, Devices and Printers, right click theprinter icon and select Troubleshoot.17 Feb 2017
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Many printers will not print if one color is out, some will. One thing to check is to make sure that when you print, the option for "balck and white" is selected in the printing preferences.
Many people don't realize that even though the document may be black and white the printer still processes it as a color document which wastes costly supplies.
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
What is the error message? SCANNER ERROR? If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
