Panasonic Toughbook CF-30 Notebook Logo
A
Anonymous Posted on Feb 04, 2014
When typing the cursor will move to a different place
When typing the cursor will move to a random line in the document so I am typing there instead of where I started typing
Cursor moves while typing
You may need to disable the touchpad. Your wrists may be brushing the touchpad, causing the cursor to move.
tip
Typing on a laptop, cursor jumps to different places, you suddenly type in a...
This is a very common problem to people who purchase a new laptop, or change from a desktop computer to a laptop. When typing, the cursor suddenly moves all over the place (but usually up) and you find yourself typing elsewhere in the document.
The secret is... the touchpad.
When typing on a standard keyboard, people usually rest their palms on the front portion of the keyboard, or on a special palmrest. Typing on a laptop is a slightly different experience - you have to keep the hands more apart, to avoid placing them on the touchpad.
But even if the hands are apart, you have to move them slightly while typing to comfortably reach the upper rows of keys. Depending on typing habits, the movements will be larger or smaller, but there is always some movement.
Now consider this. If you look at your hand from the side, you will notice, that the base of your thumb protrudes down the lowest. When moving the hands while typing, you very gently touch/stroke the touchpad with the base of your thumb - even if you don't feel it :)
Unfortunately the touchpad feels it, and acts as if you deliberately moved the cursor and placed it somewhere above the spot in the document you were actually typing in.
There are two remedies.
First, and one that has to be excercised anyway, is to try and keep the palms well above the surface of the touchpad. It takes some practice to change one's typing habits, but eventually you'll do it. It's just a matter of finding a palm placement that will be equally comfortable, but will also lower the possibility of involuntarily touching the touchpad.
Second is to go to your system's controls, find settings for the pointing device, and search for options regarding touchpad sensitivity.
There are multiple flavors of these settings, so it's not possible to give one standard recipe, but if you have an original touchpad driver installed (as oposed to using a standard mouse driver, which is enough for the system to recognize the touchpad), there should be a special settings screen for it, and among other options, a sensitivity setting.
Sometimes there's also an option (checkbox) designed specifically to fix this issue - usually it's called something like "eliminate problems with light touch" or sth to that effect.
Please try it, I guarantee that in 99% of the "sudden cursor movement" cases this is the actual cause :)
Good luck, and please don't forget to come back and rate the tip if helped :)
on Jul 24, 2010 • Computers & Internet
The cursor jumps backward often while I type, and writes behind where I am, lines behind.
You're probably hitting the touchpad with the heel of your hand while typing. Many people do it without realizing it, and the computer is just moving the cursor to where it thinks you're telling it to go. If you're doing lots of typing, you may want to plug in a USB external mouse and turn off the touchpad. This eliminates the cursor jumping, and a regular mouse makes moving around a document and selecting text easier.
I'll be typing anything and my cursor will randomly reset to an earlier place causing me to constantly correct my work. I have a brand new Dell Inspiron 15.
Mine does this quite often when I am typing. I have discovered that my hands are touching the mousepad while I am typing and will randomly put the mouse in the middle or just about anywhere in the document I am typing. The next time this happens take note of where your hands are and if they may be slightly touching the mousepad. It took me quite some time before I figured out what was happening.
2answers
Dell studio 15-cursor moves at random when typing...
these is a mouse config or drivers defective, reinstall mouse drivers, or check for virus/spyware infestation. check with online antivirus, like norton,....
Mouse keeps shifting the cursor to a different place in document
On touchpads if you touch the pad twice in quick succession it acts as a click and the cursor will move to the mouse pointer location. In mouse settings disable "tapping"
3helpful
3answers
Acer Keyboard Cursor moves without my knowledge
Someone has remote assistance to your computer. Go into Control panal and turn "Remote Assistance" off
My letters and words will randomly go in different places
Have you checked the moue and keyboard settings see if there is something in the settings...one computer I would recommend to check the keyboard wiring but with two that would be quite a coincidence. If the mouse is chasing the cursor then its got to be a software issue..also run spyware software on both. Spyware captures keystrokes so could be affecting the keyboard pointer settings.
2helpful
Typing problem
the problem is where the mouse cursor is. When you begin to type have the mouse cursor as far down the page as possible the glide pad can pick up the slightest variant of pressure and move your text to the position where the mouse cursor is.
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
