The agitator was wobbling,so i removed that and the coupler. they both look ok.The transmission shaft wobbles can move side to side.no visual signs of any oil leaking
SOURCE: GE WPRB9220D Top Load Washer
There may be nothing wrong with the splie/gearbox shaft. At the top of the agitator on the inside is a brass "dog" That may be worn and you will need to replace it.
SOURCE: GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
The
first thing to check when your GE washer is not agitating, is the belt.
Let me tell you how to check the belt & the clutch with out having
to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If
the washer drains the water and then spins the way that it should, this
tells you that the motor, belt & clutch are not the reason why your
washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The
agitator uses a plastic agitator coupler that is couple to the
transmission shaft by using splines cut in the coupler and on the
transmission shaft.
Too much
usage or overloading the washer too many times will wear the agitator
coupler splines. With out the splines the coupler could not be coupled
to the transmission shaft and that could be the cause why your washer is
not agitating.
The clutch: A
bad clutch could also be the reason the washer won't agitate or spin.
Usually when the clutch is bad the washer will be noisy, like when you
have bad brakes on your car.
The transmission: The
transmission could be the reason your washer is not agitating. A common
problem with the transmission is oil leaking right on top of the motor
pulley and the belt.
As you
can see, there could be different reasons why your GE washer is not
agitating. You just need to keep checking each part until you find the
problem and replace the part responsible.
Thanks,but i found that the outer part of the shaft is stable.The inner part of shaft is wobbling
is there a way to repair this on this model or do i need to replace the whole transmission
No the is no way but replace the transmission if you need help I am here
