290,299,209.201. Try these codes. If you wish to get more; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
SOURCE: ayuda
Set-up codes to check with Fisher Brand TVs are, 1145 1171 1347 1024 1047 1008 1143 1298 1069 1046 1072 1073 1162 1079 1131. If you wish to get more, check these links. http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or, view in 'Timeslide' option.
SOURCE: problema con control universal sony rm-vz220
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Philips. Hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 566,770,741,628, y 521. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 566#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contacteme directamente al [email protected]. Gracias y espero esto le sirva de ayuda.
