At this point I'd complain to the company as it sounds like a fire hazard. Check to see if there has been a recall on it, but I wouldn't turn it on and leave the house. It is not your fault......it is a manufacturers defect...at least that is my opinion.
SOURCE: Dryer suddenly does not produce hot air
have the exact same problem, just over 1 year old no heat! first off my duct work under my floor is like a snake and is not a straight shot out of the house. I beleive this caused a ristriction in the venting because dyer seemed to be running hotter them normal. I took the top off the dryer and pulled the vent tube out of the bottom of the dryer. To my surprise found a three inch layer of lint on the bottom of the machine and also on the heating coil. After cleaning out all the lint i took a volt meter to the two wires that come down to the heater. started the dryer and found i had 220volts at the heater indicating the heater is out, found one on ebay for about 50 bucks. will be installing this weekend and will let you know how it works.
