SOURCE: Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
SOURCE: HP L7680 Print Heads need real cleaning!
If the ink has dried up in the nozzles try putting a wet cloth in the microwave to get it hot enough to produce a little steam and set the cartridge, nozzles down on the damp cloth until ink starts to ooze from the cartridge. May require a couple of tries. Try using the cleaning program again.
Be careful not to touch the copper contacts on the cartridges.
SOURCE: Hp Deskjet D2360
here you can downlaod it form hp
Software & Driver downloads HP Deskjet D2360 Printer
select your o/s and download
riz.
SOURCE: printer light always blinking
either out of paper and something still waiting to print or inks low
hope this helps :)
