Can you hear any noise? It could be the belt which you can check by tipping back and looking from underneath. The belt runs vertically from the motor to the drum pulley at the very back of the machine. Does anything work, the drain, the water fill? If they do and only the drum won't turn and the belt is ok then it could be quite a few things. The motor itself, check the motor windings with a multimeter. The control board, again check for voltages with a meter. Wiring to the motor, visually check the wiring harnesses throughout. Will need to know what your machine does and does not do to diagnose correctly.
